how to run "share /L:50" ?
General information and assistance with DOSBox.
Postby jerfab1 » 2018-2-09 @ 20:10
Hi-
I'm trying to use DOSBox to run an old DOS program used for library cataloging called "Minaret". I've figured out how to mount the Minaret directory, and how to get to the C-drive. Next I want to run the program "minaret.exe". But, when I type "minaret" at the command line ("C:\minaret"), I get this error message:
"You must run "SHARE /L:50" before using Minaret: MSDOS 5.0"
I can't figure out how to run this SHARE command and get to the Minaret program. Can anyone help?
Thank you,
Jerry in NJ
jerfab1
Re: how to run "share /L:50" ?
Postby AlaricD » 2018-2-09 @ 20:27
jerfab1 wrote:"You must run "SHARE /L:50" before using Minaret: MSDOS 5.0"
SHARE.EXE is an MS-DOS external, which isn't included with DOSBox. It probably won't even *work* with DOSBox. If it does, and even if you can get Minaret to still run, that's not what DOSBox is for and you'll probably have some very unsatisfactory results.
"The Big Bang. The ultimate hero of low frequency. The divine intergalactical bass drum connecting the tribes of our solar system."
Yello
"Solar Driftwood"
User avatar
AlaricD
Postby JosSchaars » 2018-2-09 @ 22:23
SHARE.EXE actually doesn’t work with DOSBox: File operations are cached, while data has to be actual (in memory match that on disk) for record locking to function reliable.
JosSchaars
Return to DOSBox General
Who is online
Users browsing this forum: No registered users and 2 guests
