First post, by timj
greetings! first of all thank you very much for this amazing tool 👍
i did a search and couldn't find any info on this, maybe it's not supported but i was wondering if there's any way that could launch a game with a specific keymapper file.
i have these shortcuts and wanted to do something like this, e.g.:
"C:\Program Files (x86)\DOSBox-0.74\DOSBox.exe -mapper-0.74.map" "D:\Games\DOS\flashback\fb.exe" [for flashback game]
"C:\Program Files (x86)\DOSBox-0.74\DOSBox.exe -mapper-0.75.map" "D:\Games\DOS\fotf\go.bat" [for fury of the furies]
etc...
in order to avoid the necessity to always enter the keymapper every time i want different key configurations according to each game i play...
i hope my question makes sense...
thanks in advance 👍
Reply 1 of 2, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
You can prepare special conf files for each game with the right mapper file referenced in it.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 2, by timj
hey thanks for your fast reply!
i went to appdata\local\dosbox and copied dosbox-0.74.conf and mapper-0.74.map to the directory where i have my game, D:\Games\DOS\flashback\.
then i renamed them both to dosbox-flashback.conf and mapper-flashback.map and finally i edited my shortcut and used this command:
"C:\Program Files (x86)\DOSBox-0.74\DOSBox.exe -conf D:\Games\DOS\flashback\dosbox-flashback.conf" "D:\Games\DOS\flashback\fb.exe"
but unfortunately windows gives me this message:
9.76 KiB
edit: i did it :jots is down: hehe, turns out i had to edit the dosbox-0.74.conf file and in the end of if write my mount commands, thanks a lot!!!
feel free to delete the thread if you want 👍
