First post, by FlatAssembler
Hey, guys!
New here. I've just made a simple web-app that attempts to convert arithmetic expressions to i486-compatible assembly:
Arithmetic expression to assembly converter
(My website sleeps from 22h to 23h GTM+1.)
I've tried to test it (using Flat Assembler), and to me it seems like it produces correct results. However, I am not a professional programmer, so I would like to hear from some experts (and I guess people who know the details of a program such as DosBox are experts on those things).
Reply 1 of 4, by Falcosoft
It's an interesting idea and actually it can be quite useful.
Just a few observations:
1. It treats everything as floating point. So the simple arithmetic expression '1+1' generates single precision FPU code instead of more reasonable integer code. So the code is only 486DX+ compatible and cannot work on 486SX.
2. '123456789.123456789 + 123456789.123456789' also generates single precision FPU code though in this case double or even extended precision (or an option) could be more useful.
Otherwise the code seems to be OK although not the most optimized (finit is a speed killer for small routines and also resets control word. I would rather omit it).
Website, Facebook, Youtube
VST Midi Driver Midi Mapper
Reply 2 of 4, by FlatAssembler
So, do you think I am good at programming? Is it worth continuing?
If so, what would you recommend me to learn next? I've made that in JavaScript, and that's the only programming language I know well enough to be able to do that in it.
Reply 3 of 4, by FlatAssembler
OK, I get it. This isn't a good forum for such questions.
Reply 4 of 4, by FlatAssembler
Anyway, I've improved my compiler using the Duktape framework to be able not only to translate single directives from my own programming language into Assembly, but to also be able to translate entire simple programs stored in files. Here is one of the first programs I've written in the first programming language I've made myself:
;Advanced example: implementing the permutation algorithm.
AsmStart
debug=0
macro pushIntToStack x
sub esp,4
fld dword [x]
fistp dword [esp]
macro pushPointerToStack x
sub esp,4
lea ebx,[x]
mov [esp],ebx
macro pushStringToStack x
sub esp,4
mov dword [esp],x
format PE console
entry start
include 'win32a.inc'
section '.text' code executable
start:
jmp enterNumber$
enterNumber db "Enter a whole number (1 - 1'000'000).",10,0
enterNumber$:
pushStringToStack enterNumber
call [printf]
pushPointerToStack original
jmp floatSign$
floatSign db "%f",0
floatSign$:
pushStringToStack floatSign
call [scanf]
jmp permutationString$
permutationString db "The permutations of its digits are:",10,0
permutationString$:
pushStringToStack permutationString
call [printf]
AsmEnd
numberOfDigits:=0
i:=0
While i<10
countDigits[i]:=0
i:=i+1
EndWhile
While original>0
numberOfDigits:= numberOfDigits + 1
lastDigit:= mod( original , 10 )
countDigits[ lastDigit ]:=countDigits( lastDigit ) + 1
original:= (original - lastDigit) / 10
EndWhile
AsmStart
if debug=1
AsmEnd
i:=0
Show last 123 lines
		While i<10
subscript:=4*i
AsmStart
fld dword [subscript]
fistp dword [subscript]
mov ebx,[subscript]
pushIntToStack (countDigits+ebx)
pushStringToStack integerSign
call [printf]
AsmEnd
i:=i+1
EndWhile
AsmStart
pushStringToStack newLineString
call [printf]
AsmEnd
AsmStart
end if
AsmEnd
topOfMyStack:=1
myStack[(numberOfDigits+1)]:=0
While topOfMyStack>0
currentNumberOfDigits:=myStack ( topOfMyStack * ( numberOfDigits + 1 ) )
i:=0
While i<currentNumberOfDigits
currentNumber(i):=myStack ( topOfMyStack * ( numberOfDigits + 1 ) + ( i + 1 ) )
i:=i+1
EndWhile
AsmStart
if debug=1
AsmEnd
i:=0
subscript:=i*4
AsmStart
mov ebx,[subscript]
pushIntToStack (currentNumber+ebx)
call [printf]
AsmEnd
i:=i+1
EndWhile
AsmStart
call [printf]
AsmEnd
AsmStart
end if
AsmEnd
topOfMyStack:=topOfMyStack-1
If currentNumberOfDigits=numberOfDigits
i:=0
While i<numberOfDigits
subscript:=i*4
AsmStart
mov ebx,[subscript]
call [printf]
AsmEnd
i:=i+1
EndWhile
AsmStart
call [printf]
AsmEnd
Else
i:=0
While i<10
counter:=0
j:=0
While j<currentNumberOfDigits
If currentNumber(j)=i
counter:=counter+1
EndIf
j:=j+1
EndWhile
If counter<countDigits(i)
topOfMyStack:=topOfMyStack+1
myStack(topOfMyStack*(numberOfDigits+1)):=currentNumberOfDigits+1
j:=0
myStack(topOfMyStack*(numberOfDigits+1)+(j+1)):=currentNumber(j)
j:=j+1
EndWhile
myStack (topOfMyStack * (numberOfDigits + 1) + (j + 1) ) := i
EndIf
i:=i+1
EndWhile
EndIf
EndWhile
AsmStart
invoke system,_pause
invoke exit,0
_pause db "PAUSE",0
integerSign db "%d",0
newLineString db 10,0
section '.rdata' readable writable
original dd ?
result dd ?
lastDigit dd ?
numberOfDigits dd ?
countDigits dd 11 dup(?)
subscript dd ?
myStack dd 1000 dup(?)
topOfMyStack dd ?
counter dd ?
i dd ?
currentNumber dd 11 dup(?)
currentNumberOfDigits dd ?
j dd ?
section '.idata' data readable import
library msvcrt,'msvcrt.dll'
import msvcrt,printf,'printf',system,'system',exit,'exit',scanf,'scanf'
AsmEnd
The source code of the compiler, as well as the instructions on how to compile it and use it, can be downloaded here.
So, what do you think about it? Is it worth continuing developing it?
I am also dreaming about making my own LISP-like language, in which you will able to use both S-expressions and infix-expressions (since S-expressions come handy in array and string-manipulation, and infix-expressions come handy in arithmetic expressions), but I am unlikely to have time to develop it in foreseeable future.
