DOSBox 0.74 shows a white screen
General information and assistance with DOSBox.
Postby theepicjoshua » 2018-7-10 @ 22:57
So, I started up my DOSBox, one day, and I saw a white screen. Nothing on it, No logo, Just that; a white blank screen.
I uninstalled it, reinstalled it, nothing changed. Just the same old white screen. Staring at me as if I didn't touch it.
I am using Windows 10 64-bit: Version 1803
Hopefully, someone will find a solution to this problem.
Thank you.
- Josh
theepicjoshua
Re: DOSBox 0.74 shows a white screen
Postby Qbix » 2018-7-11 @ 06:05
which video card do you have and which drivers ?
Water flows down the stream
User avatar
Qbix
DOSBox Author
Postby Yesterplay80 » 2018-7-11 @ 09:06
Have you tried a much more recent SVN release? 0.74 is some years old by now, maybe a current SVN works much better.
My full-featured DOSBox SVN builds (without debugger) for Windows: Vanilla DOSBox and DOSBox ECE (Enhanced Community Edition)
User avatar
Yesterplay80
Postby theepicjoshua » 2018-7-12 @ 02:06
Qbix wrote:which video card do you have and which drivers?
Did you mean what 'Display adapters' I have or what 'graphics card' I have?
If you meant what Display adapter I have, I have an Intel HD Graphics 3000.
If you meant what Graphics Card I have, well, it's hard to say and believe, but I don't have one.
But, that's not to say it hasn't worked before, it has worked before.
- Josh
theepicjoshua
Postby Qbix » 2018-7-12 @ 14:41
Thanks, that was what I was asking for.
I suspect that a driver has updated (maybe by microsoft or by intel) as there are suddenly 3 people with this problem. (Got 2 by email as well)
Can you check when the driver of your display adapter was updated ?
User avatar
Qbix
DOSBox Author
Postby theepicjoshua » 2018-7-12 @ 20:48
Qbix wrote:Thanks, that was what I was asking for.
Sure! I believe the last time it was updated was on the 22nd of June, 2018.
- Josh
theepicjoshua
Postby theepicjoshua » 2018-7-13 @ 00:04
Yesterplay80 wrote:Have you tried a much more recent SVN release? 0.74 is some years old by now, maybe a current SVN works much better.
Hey, I just tried the latest version of DOSBox, which is r4130. Nothing changed. Just the same white screen as if nothing ever happened to it.
- Josh
theepicjoshua
Postby DosFreak » 2018-7-13 @ 00:45
DOSBox 0.74 working fine on Windows 10 x64 w/ Intel HD Graphics 530 v24.20.100.6194 6/20/2018
Wonder if 1803 is incompatible with old Intel HD drivers. On the Intel site the highest OS is Windows 8 for the Intel HD 3000.
User avatar
DosFreak
Postby ripsaw8080 » 2018-7-13 @ 01:38
Are you using the output=surface setting, which is the default? If so then try the output=opengl setting.
User avatar
ripsaw8080
DOSBox Author
Postby theepicjoshua » 2018-7-13 @ 13:15
ripsaw8080 wrote:Are you using the output=surface setting, which is the default? If so then try the output=opengl setting.
I tried changing the Output setting from ‘surface’ to ‘opengl’ and it actually fixed my problem! I still don’t have a logo on startup, but the important thing is, it works. Thanks!
- Josh
theepicjoshua
Postby Qbix » 2018-7-13 @ 19:37
if you are still hanging around.
Could you tell us with which version of dosbox this was ?
User avatar
Qbix
DOSBox Author
Postby theepicjoshua » 2018-7-13 @ 22:03
Qbix wrote:if you are still hanging around.
I tried it on both the SVN and 0.74, I believe. They both worked fine.
- Josh
theepicjoshua
Return to DOSBox General
Who is online
Users browsing this forum: No registered users and 3 guests
