Problems installing Windows 95
General information and assistance with DOSBox.
Postby Vermillion_Catus » 2018-7-19 @ 01:13
So, I wanted to install Windows 95 in DosBox, for which I'm using this guide:
http://dosbox95.darktraveler.com/index.html
The problem is that when I put the command "setup.exe /nm /is" the response I get is "Access denied".
I suspect this is because the file "Setup.exe" needs admin permission to be opened, but i don't know how to do that.
Searching for an answer I found that there is a command called "runas" which has probably something to do with allowing admin permission, but when I used it the response i got is "Bad command or file name".
Vermillion_Catus
Re: Problems installing Windows 95
Postby leileilol » 2018-7-19 @ 02:06
Congratulations! You've been misled by the internet.
DOSBox does not support running Windows 95.
by the way, DOSBox is not for running Windows 9x
User avatar
leileilol
Postby Vermillion_Catus » 2018-7-19 @ 02:42
leileilol wrote:Congratulations! You've been misled by the internet.
There are a lot of videos proving that it's possible, and there's even a guide in this same forum talking about how to do it.
viewtopic.php?f=39&t=24936
I've been trying to install Windows 95 for two straight days now, and this is the first time that I hear someone saying that it's impossible.
Maybe you mean that it's impossible to do so in the DosBox 0.74 version. I haven't checked that, so I don't now if it's possible or not, but I'm using DOSBox SVN-Daum, and from all the info that I could gather there's no reason to believe it's impossible.
Can you at least explain why it's impossible to do? and give consist proof, please.
Vermillion_Catus
Postby leileilol » 2018-7-19 @ 03:44
It's not impossible, it's just not supported. Nothing in DOSbox is made for running Windows 95.
What's definitely impossible is running it without meeting a BSOD, running it without the ability to mount your host cd-rom drive, impossible to have directdraw chromakey transparency (breaking the prospect of windows gaming) etc.
User avatar
leileilol
Postby DosFreak » 2018-7-19 @ 11:39
First: you should find out if you need to run Windows 95 or not. If you don't know then likely you do not.
Second: DOSBox does not support Windows 95 as a guest but the errors you are receiving lead me to believe you are using the Windows Command prompt instead of DOSBox since Windows 95 installs fine in DOSBox (except for when it gets to the configuring part sometimes).
Third: Install Windows 95 on pcem, virtualbox, vmware, qemu, bochs etc.
Closed
User avatar
DosFreak
Return to DOSBox General
Who is online
Users browsing this forum: No registered users and 3 guests
