Change disk wile program is running
General information and assistance with DOSBox.
Postby Roman78 » 2018-8-13 @ 11:06
I encountered a problem which i was unable to resole. I have some disk images of Floppies. I mounted the first one, started the installation of this floppy. After some seconds it tells me to insert disk 2 into drive A:. And there i'm stuck.
I tried to copy the files to the harddisk, but it needs to be installed via the installer on the Floppy.
So is there away the change the floppy from disk01.img into disk02.img while i am unable to enter the imgmount command?
Roman78
Re: Change disk wile program is running
Postby Qbix » 2018-8-13 @ 11:07
if you use the SVN version of dosbox, then you can do that, by mounting them all (imgmount a disk1.img disk2.img ......) and press ctrl-f4 to switch
Water flows down the stream
User avatar
Qbix
DOSBox Author
Postby Roman78 » 2018-8-14 @ 12:12
What is the SVN version? I just downloaded it from dosbox.com, the 0.74v.
Roman78
Postby Qbix » 2018-8-14 @ 12:16
I'll pm you it.
User avatar
Qbix
DOSBox Author
Return to DOSBox General
Who is online
