First post, by rafik73
Greetings
I am new here, so welcome.
I want to use Dosbox to run an old program under DOS secured with an LPT key (the key is Dallas Semiconductor). The software manufacturer recommends some settings in the configuration files, namely:
AUTOEXEC.BAT FILE EXAMPLE FOR VIK PROGRAMSFOR WINDOWS 95 OPERATIVE SYSTEM'S COMPUTER@ECHO OFFC:\WINDOWS\SMARTDRV.EXE 1024 /VPATH=C:\WINDOWS\COMMAND;C:\WINDOWS;C:\APMSET TEMP=C:\WINDOWS\COMMANDSET :HOME:=C:\APMPROMPT $P$GC:\MOUSE\MOUSEC:\WINDOWS\COMMAND\KEYB IT,,C:\WINDOWS\COMMAND\KEYBOARD.SYS /EC:\WINDOWS\COMMAND\DOSKEY.COMMODE CON: DELAY=1 RATE=32CONFIG.SYS FILE EXAMPLE FOR VIK PROGRAMSFOR WINDOWS 95 OPERATIVE SYSTEM'S COMPUTERDEVICE=C:\WINDOWS\HIMEM.SYSDEVICE=C:\WINDOWS\EMM386.EXE RAMBUFFERS=30,0FILES=30DOS=UMBLASTDRIVE=ZFCBS=16,0DOS=HIGHDEVICE=C:\WINDOWS\COMMAND\ANSI.SYSCOUNTRY=039,,C:\WINDOWS\COMMAND\COUNTRY.SYSSTACKS=9,256******************************************************************************AUTOEXEC.BAT FILE EXAMPLE FOR VIK PROGRAMSFOR MS-DOS 6.22 OPERATIVE SYSTEM'S COMPUTER@ECHO OFFC:\DOS\SMARTDRV.EXE 1024 /VPATH=C:\DOS;C:\APMSET TEMP=C:\DOSSET :HOME:=C:\APMPROMPT $P$GC:\MOUSE\MOUSEC:\DOS\KEYB IT,,C:\DOS\KEYBOARD.SYS /EC:\DOS\DOSKEY.COMMODE CON: DELAY=1 RATE=32CONFIG.SYS FILE EXAMPLE FOR VIK PROGRAMSFOR MS-DOS 6.22 OPERATIVE SYSTEM'S COMPUTERDEVICE=C:\DOS\HIMEM.SYSDEVICE=C:\DOS\EMM386.EXE RAMBUFFERS=30,0FILES=30DOS=UMBLASTDRIVE=ZFCBS=16,0DOS=HIGH
DEVICE=C:\DOS\ANSI.SYSCOUNTRY=039,,C:\DOS\COUNTRY.SYSSTACKS=9,256
How do you apply these settings in DOSBOX?
