Changeing CD drives
First post, by TheGoast
I Have had a good serch but i may have mist some thing.
I am running a game in dosbox ok no problems.
Thing is as hard drives are getting bigger i am copying my favorate old DOS game CD's on to one HD, each CD in a Folder.
This works fine for most games, all i do is create a BAT file in the root dir for each game with a comad to mount the relavant folder as a CDROM Drive (mount D "path of reavant folder" -t cdrom)
Unfortunatly I have a broblem with some games and I need help.
Some games require the CD changing half way through the Game.
Is there a way that a HOT key can be set to unmout the existing cdrom and mount a new one.
i.e. emulate fisicaly changing a CD.
Reply 1 of 10, by eL_PuSHeR
Just swap CDs and press CTRL-F4 (rescan) inside DOSBox.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 10, by TheGoast
Its not a fisical CD i want to change Its another folder i want to mount as a CD replasing the one that is curently mounted while the game is running
Reply 3 of 10, by eL_PuSHeR
Use some utility to generate ISO, BIN+CUE images from CD and mount them using DAEMON TOOLS or something. After mounting a new one, use CTRL-F4 under DOSBox.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 4 of 10, by `Moe`
Isn't DOSBox's own IMGMOUNT capable of mounting several images swappable with Ctrl-F4? No need for Daemontools then.
Reply 5 of 10, by eL_PuSHeR
You are right. IMGMOUNT should work nice too. Just read the readme.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 6 of 10, by rcblanke
Are you guys sure this is possible? I couldn't find anything about mounting multiple images using IMGMOUNT. Would be very usefull for multiple CD games though, such as The 7th Guest and the like...
Regards,
Ronald
Reply 7 of 10, by TheGoast
The trouble I have is I need to be able to do it while the game is running.
Can't enter comands while the game is runnig.
Ctrl-F4 only updates changes made to the data altered outside the DOSbox
I was hoping there was some way of fixing a comand to a HOTkey
Somthing like this:
mount -u d:
mount d H:\DW2CD1 -t cdrom -label DW2_CD1
Reply 8 of 10, by rcblanke
ctrl-f4 works fine when a game is running, like in booter games
Reply 9 of 10, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
according to the readme imgmount can't do that (mounting several images), only boot, so daemon tools are the only way to go.
Reply 10 of 10, by TheGoast
Thanks for the help
