Reply 40 of 42, by _Rob
even easier:
imgmount d win98.iso -ide 2m
You don't need to specify -fs none or -t iso (it will automatically detect it as iso). Even -ide 2m is not needed in most cases.
Reply 41 of 42, by Sebiohazard
Ok thank you 😀
I also discovered that it is possible to create a virtual HDD in .vhd format which is very convenient to mount it in Windows 10 Explorer with the command:
imgmake WIN98.vhd -t hd -size 1024 -nofs
Greetings !
Reply 42 of 42, by _Rob
why "-nofs"? imgmake can create fat 12, 16 or 32. And if it is a "-t hd", it will also automatically partition it (unless you use the -nofs flag).
imgmake WIN98.vhd -t hd -size 1024 -fs fat32
