First post, by M_Alex
I have been using DOSbox for some time, and everything was fine. Last week i had to format my drive and reinstall the system [windows XP in my case, with service pack 2]. Since then i have begun getting a strange error with DOSbox:
When i launch it, and switch to full screen mode, it crashes upon running an application. If I run an application in windowed mode, then switch to fullscreen the program runs pretty normal, but the stability is lower then it should be. Any ideas what this could be / how to resolve this problem?
Best Regards,
M. Aleksander Miernik
