Serial port on linux
Reply 20 of 23, by nicola
This code:
	termInfo.c_cc[VMIN] = 0;
termInfo.c_cc[VTIME] = 0;
is for non canonical mode. So I add also:
termInfo.c_lflag &= ~(ICANON);
Now step5 still doesn't work, but it receives wrong chars.
So someting changed. 😁
I should continue investigate in the code.
Who is linux patch's author ? Maybe he could know something about it.
Thanks, Nicola.
Reply 21 of 23, by wd
Rank DOSBox Author
DOSBox Author
> Who is linux patch's author?
Um...well...have a closer look at that submitter of the patch on sourceforge.
Most stuff still is from hal/canadacow.
Reply 22 of 23, by nicola
Work ! 😁 😁 😁
I changed:
to:
termInfo.c_lflag &= 0;
Now I will try to work on step5.
Thanks, Nicola.
P.S. Why there isn't the code complete on posix patch?
Hal, do you make work step5 v3.0 on linux or only on windows ?
Reply 23 of 23, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Nice 😀
The patch submitter uses it for the second mouse in 'the settlers' which it seems to be sufficient for. For a mouse only receiving data is required.
Only Windows. And it's more a hobby than work. I'm trying to make a simpe replacement...
1+1=10
