Reply 20 of 27, by collector
- l33t
Thanks a lot. I'll give this a try later tonight.
I have had a chance to check it out. Can you make the shortcut be just standard Windows shortcuts? The config file shouldn't have to go through the frontend just to play. It doesn't seem to accept the changes from direct editing of the config file. If it was a standard Windows shortcut, it could use a normal dosbox.conf. As far as the config file goes, it might be a good idea to simply have it named dosbox.conf. if it is in the game's folder, there is no danger of over writing another dosbox.conf.
What I would find VERY convenient would be to be able to invoke a shortcut/config file on a right click of the executable directly in the game's folder, without having to first open the frontend. I would like to see a "Create shortcut/config file" pair, a "Configure game" (that would bring up the profile in the GUI for editing) and a "Run in DOSBox" (which would mount and run the game with a default config file) as a shell extension. These could be cascaded under a TDB context menu to prevent the right click from getting too large.
One last thought, there has been some discussion about standardizing profile formats to make them interchangeable/importable between frontends. I would propose a frontend subforum where the threads for the different frontends could go as well as for generalized discussions about frontends, like standardization.
