Franpa@PAUL ~/sdl-1.2.11
$ make native
make install prefix=/usr
make[1]: Entering directory `/home/Franpa/sdl-1.2.11'
cp -rv bin include lib share /usr/
`bin/i386-mingw32msvc-sdl-config' -> `/usr/bin/i386-mingw32msvc-sdl-config'
`bin/SDL.dll' -> `/usr/bin/SDL.dll'
`include/begin_code.h' -> `/usr/include/begin_code.h'
`include/close_code.h' -> `/usr/include/close_code.h'
`include/SDL.h' -> `/usr/include/SDL.h'
`include/SDL_active.h' -> `/usr/include/SDL_active.h'
`include/SDL_audio.h' -> `/usr/include/SDL_audio.h'
`include/SDL_byteorder.h' -> `/usr/include/SDL_byteorder.h'
`include/SDL_cdrom.h' -> `/usr/include/SDL_cdrom.h'
`include/SDL_config.h' -> `/usr/include/SDL_config.h'
`include/SDL_config_amiga.h' -> `/usr/include/SDL_config_amiga.h'
`include/SDL_config_dreamcast.h' -> `/usr/include/SDL_config_dreamcast.h'
`include/SDL_config_macos.h' -> `/usr/include/SDL_config_macos.h'
`include/SDL_config_macosx.h' -> `/usr/include/SDL_config_macosx.h'
`include/SDL_config_minimal.h' -> `/usr/include/SDL_config_minimal.h'
`include/SDL_config_os2.h' -> `/usr/include/SDL_config_os2.h'
`include/SDL_config_win32.h' -> `/usr/include/SDL_config_win32.h'
`include/SDL_copying.h' -> `/usr/include/SDL_copying.h'
`include/SDL_cpuinfo.h' -> `/usr/include/SDL_cpuinfo.h'
`include/SDL_endian.h' -> `/usr/include/SDL_endian.h'
`include/SDL_error.h' -> `/usr/include/SDL_error.h'
`include/SDL_events.h' -> `/usr/include/SDL_events.h'
`include/SDL_getenv.h' -> `/usr/include/SDL_getenv.h'
`include/SDL_joystick.h' -> `/usr/include/SDL_joystick.h'
`include/SDL_keyboard.h' -> `/usr/include/SDL_keyboard.h'
`include/SDL_keysym.h' -> `/usr/include/SDL_keysym.h'
`include/SDL_loadso.h' -> `/usr/include/SDL_loadso.h'
`include/SDL_main.h' -> `/usr/include/SDL_main.h'
`include/SDL_mouse.h' -> `/usr/include/SDL_mouse.h'
`include/SDL_mutex.h' -> `/usr/include/SDL_mutex.h'
`include/SDL_name.h' -> `/usr/include/SDL_name.h'
`include/SDL_opengl.h' -> `/usr/include/SDL_opengl.h'
`include/SDL_platform.h' -> `/usr/include/SDL_platform.h'
`include/SDL_quit.h' -> `/usr/include/SDL_quit.h'
`include/SDL_rwops.h' -> `/usr/include/SDL_rwops.h'
`include/SDL_stdinc.h' -> `/usr/include/SDL_stdinc.h'
`include/SDL_syswm.h' -> `/usr/include/SDL_syswm.h'
`include/SDL_thread.h' -> `/usr/include/SDL_thread.h'
`include/SDL_timer.h' -> `/usr/include/SDL_timer.h'
`include/SDL_types.h' -> `/usr/include/SDL_types.h'
`include/SDL_version.h' -> `/usr/include/SDL_version.h'
`include/SDL_video.h' -> `/usr/include/SDL_video.h'
`lib/libSDL.dll.a' -> `/usr/lib/libSDL.dll.a'
`lib/libSDL.la' -> `/usr/lib/libSDL.la'
`lib/libSDLmain.a' -> `/usr/lib/libSDLmain.a'
`share/aclocal/sdl.m4' -> `/usr/share/aclocal/sdl.m4'
make[1]: Leaving directory `/home/Franpa/sdl-1.2.11'
$ cd ..
Franpa@PAUL ~
$ cd dosbox-0.70
Franpa@PAUL ~/dosbox-0.70
$ autogen.sh
Generating build information using aclocal, autoheader, automake and autoconf
This may take a while ...
Now you are ready to run ./configure.
You can also run ./configure --help for extra features to enable/disable.
$ ./configure
checking build system type... i686-pc-mingw32
checking host system type... i686-pc-mingw32
checking target system type... i686-pc-mingw32
checking for a BSD-compatible install... /bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether make sets $(MAKE)... (cached) yes
checking for gcc... gcc
checking for C compiler default output... a.exe
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables... .exe
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking how to run the C preprocessor... gcc -E
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking for ranlib... ranlib
checking for sdl-config... /bin/sdl-config
checking for SDL - version >= 1.2.0... no
*** Could not run SDL test program, checking why...
*** The test program failed to compile or link. See the file config.log for the
*** exact error that occured. This usually means SDL was incorrectly installed
*** or that you have moved SDL since it was installed. In the latter case, you
*** may want to edit the sdl-config script: /bin/sdl-config
configure: error: *** SDL version 1.2.0 not found!
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
