First post, by babylon-shoes
finally i compiled dosbox cvs with mingw/msys.
and dosbox.exe is 12MB (!)
and it (seems to) run old dos games ok.
is this normal? 0.63 only had 1.6MB.
i did have to compile SDL from tar ball - configure, make, make install
i did have to use the older directx (from www.libsdl.org/extras/win32/common/directx-devel.tar.gz. newer directx headers for compiling mplayer/mencoder - audio-video - port from linux won't work)
there are other 'packages' in msys "root" which are used with mplayer. would this affect dosbox compilation or its size?
