First post, by XSmoke
XSmoke
Offline
When I switch to full screen, monitor turns off. It's not funny. Nothing helps. Helpme! 😕
blame your monitor.
try looking at the refresh rates your monitor supports. See if you can set it high enough. (at least higher then 60 hz)
Water flows down the stream
