First post, by ian_hawdon
Hi, i mainly use dosbox to run windows 3.11
the main problem is when i use alt-tab, windows xp kicks in!
how do i tell dosbox not to forword that command to windows xp?
Windows 3.1, the most stable version of windows yet! 😀
Visit http://s1mp3.secret.com.br (muS1c PoD)
Reply 2 of 7, by ian_hawdon
how do you use the key mapper?
Reply 4 of 7, by ian_hawdon
What do i change when i am in there?
Reply 6 of 7, by ian_hawdon
There is no readme in the CVS version i use!
but, i have made the alt key funtion under the alt key and the menu key (the button between alt gr and ctrl on the right hand side
That seems to work!
Reply 7 of 7, by HunterZ
You should be installing CVS builds over the top of the 0.63 release so that you get those extra support files (readme, DLLs, example dosbox.conf, etc.).
Well, except dosbox.conf, which is better to have dosbox regenerate for you so you can see the newer options in it.
