First post, by Virt
Anyone had this problem before?
Atm i'm playing Eye of the beholder II and i prefer to move around using my 7,8,9 on the numeric keyboard for easier search and movement ingame.
The problem is that when i move to fast around with 9 (turn right) then it stops reacting and only works once in a while.
I can turn around all i like with the 7 (turn left) and just as fast as i like it,but turn right with 9 seems to causde some problems.
I tried to remap the 7,8,9 to my arrowkeys but that does not seem to help,and it's not because the 9 key is broken or anything.
My CPU use is constantly running at 7-8% so i don't suspect it has something to do with that.
Anyone had this problem before and know what to do?
Thanks.
Virt.
