First post, by Kaare
I have compiled a heavy debug version of DosBox, when i start Dosbox the debug window appears correctly. My problem is that i can't stop the game and enable the debugger by pressing the PAUSE key as stated in the guide in the Guides forum!
I am using a danish keyboard layout, and checked the bindings with the keymapper (CTRL-F1) and it says the PASUE key is binded to Pause.
What am i doing wrong, or is there somthing i have to change to get this to work?
Thanks in advance
Reply 1 of 6, by Kaare
As an update i can tell that if i go into the keymapper and chooses for example, the 'W' key and want to push 'Add' and then hit my PAUSE key then nothing happens? Its like DosBox does'nt know my PAUSE key?
The layout around the PAUSE key looks like this:
_______ ______ ______
|Prt Scr| | Scroll| | Pause|
Sys Rq | | Lock | | Break|
Anyone with some idea?
Reply 6 of 6, by HunterZ
See the CVS thread (look in my signature below) for a link to info on how to generate a new .conf file. If you do this with a recent CVS version it should include that new option.
