First post, by Alphamale
Does anyone know if you can make an Audigy sound card work w/ dosbox6.3? Its not on their list but surel someone has done it. Thanks for your help.
The list of soundcards you see 'supported' by DOSBox, does not indicate what soundcards will work with the program. Rather, the list is comprised of the soundcards the program 'emulates'. The soundcards you see listed that are 'supported' by DOSBox are old(er) legacy cards and/or chips which are either incompatible with the current line of Operating Systems or hardware in today's computers.
Rest assured DOSBox works with Audigy cards fine. I have an Audigy Gamer, and it works without a hitch.
-Trebor
