First post, by Guest
Simply, the problem is that 'Delete' key produces a . (dot) mark.
I'm using Keyb (from FreeDOS) to get alphabets like ä and ö working (using the finnish (SU) layout). When looking into keymapper, 'Delete' key is assigned to 'key_delete' (or something like that) like it should be, but no matter what / where it doesn't delete anything, just gives me dots.
Any ideas? 😄
Reply 2 of 9, by Guest
Tried that now, 'Num Lock' doesn't have any effect on either Delete keys working.
Also, I found out that if I delete the "keyb su" line from dosbox.conf (autoexec part), thus not loading the keyb at all, both deletes work like they are supposed to.
The specific I'm using is http://www.ibiblio.org/pub/micro/pc-stuff/fre … /keyb/kblayout/ > kpdos22s.zip > Source/Keydos/Su.key , but I couldn't make much sense of the contents 😒
Any more kind advices? 😀
Reply 7 of 9, by wd
Rank DOSBox Author
DOSBox Author
Didn't test the 0.63 release.
You could try the freedos keyb (both older versions and the
keyb2pre3) under real dos, maybe this is just how they implemented
it (read something similar on their forum).
Reply 8 of 9, by wd
Rank DOSBox Author
DOSBox Author
Seems to be related to the pre3-version of keyb, the del-key
produces dots on a real system as well. So it is not dosbox related.
Maybe you can find an older version of keyb (pre1 seems to work).
