First post, by Skarr
If, in XP, you use a registry modification to disable that idiotic F-Lock key (e.g. http://www.mvps.org/jtsang/flock-e.html), if won't work with Dosbox - F-Lock still needs to be turned on in DB.
Reply 1 of 1, by DosFreak
Well according to that site:
It may not work in games that use the keyboard via DirectInput
I'm assuming that SDL (Which DosBox uses to communicate to the host) uses DirectInput. If so then there ya go.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
