First post, by oddnerd
I am trying to play hocus pocus and the old duke nukem which run in win16 but my system is win32. Which of the files do i need to downlad to get these to work?
Reply 1 of 3, by DosFreak
You shouldn't need to download anything since those games should work fine in XP. (Assuming you like XP's sound emulation and that your not encountering the 16bit subsystem problem.....or the giveio.sys problem or inability to use EMS problem or...etc)
What exactly is your problem with running the game? Have you tried to run it?
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 2 of 3, by oddnerd
I get this message when i try to run Duke 3d
16 bit subsystem
C:\windows\system32\autoexec.nt. the system file is not suitable for running ms dos and windows applications.
I get this when trying to run other old games like warcraft1 as well as the others i mentioned.
Reply 3 of 3, by DosFreak
Read this: 16-bit subsystem error "Your system is not suitable for running 16-bit apps"
