Using DosBox in general
First post, by Krystal
Hey,
I have just downloaded DosBox but I hvae no idea how to use it. I'm not familiar with the dos technical jargon, (so the readme files and dos-help pages are meaningless) so I'd be very grateful if somebody explained what commands I must type to run a dos game. Charlie the Duck, in particular. I have windows xp.
I posted this here because I'm asking for help running any program. Please don't move it to the other board because then I won't be able to reply.
Thanks very much!!
Reply 1 of 3, by HunterZ
You might want to check out a frontend such as D-Fend that will let you use a GUI to handle much of the configuration and setup.
Reply 2 of 3, by Tiger-Heli
First off, are you sure Charlie-the-Duck is DOS?
I checked here - http://www.games-for-pc.com/ACTION/Charlie-the-Duck.htm and it says it is for Win95/98/Me/ (although that might mean XP won't install it, and DosBox MIGHT be able to help then.
Do you have the game on your HD or on a floppy somewhere? (and where is it).
See http://www.abandonia.com/main.php?nav=index&FAQ=1
DOSBox Guides
The Newbie's Pictorial Guide To DOSBox
60 seconds guide to getting your game to run in DOSBox
About the only true DOS commands you would need to know are:
CD - Change directory - CD Games for example
CD\ - returns to top level directory.
CD . . - Moves up one level in directory tree
mount - Installs a drive or directory
gamename.com, gamename.bat, gamename.exe - launches the game where gamename is something like F117A, CHDUCK (guessing), FALCON3, etc.
Exit - ends DosBox
Post back if you need more help.
Reply 3 of 3, by Freddo
I just tried the Charlie the Duck demo. While the installer is a Windows program, the actual game is a DOS program.
Instructions how to run Charlie the Duck on a modern computer with DOSBox.
1) Install Charlie the Duck into C:\GAMES\CHARLIE
2) Start DOSBox
3) Type MOUNT C C:\GAMES
4) Type C:
5) Type CD CHARLIE
6) Type CHARLIE
And the game should run. Press CTRL+F12 until you're up to 7000 cycles and go into options in the game and set the background as "Static".
You can use the "Parallax" background if you want, as it looks slightly better but require more resources so you have to raise the cycles even more and maybe you don't have the CPU power enough to do so. But you can try. Also, with no background you can use less cycles if 7000 is too much to handle, but I doubt that.
Also note that you shouldn't install the game into the default path, as DOS is restricted to names 8 characters long and a folder named "Charlie the Duck" is too long.
