First post, by sehh
- Newbie
i'm running dosbox 0.63 under both Linux (Fedora Core 4) and WinXP Pro. The configuration is the same for both.
Unfortunately, i've a problem with Eye of the Beholder 2. The audio is delayed by several seconds under Linux only. It works fine under WinXP. For example, once i click on a door button, i see the door close and once its closed i can hear the sound of the door closing. Very weird. It happens on all EYE2 sounds.
Other games work fine.
Any suggestions please?
sehh
