First post, by D131
I have a few problems with DOSbox memory sizes. Some games that I would like to play with DOSbox are snail-like slow, so I thought that adding some memory -within- DOSbox could speed things up. My guess is that I should add conventional OR extended OR expanded memory. The question is how do I do that? I searched thru the FAQ etc and found nothing (or I'm just blind)
I run a Pentium 4 (3ghz), 1gb ram, with Windows XP SP2. (if that's any use)
