First post, by Guest
Forgive me if im not placeing this in the right forum but i am still very new to this.
The problem that im having is that i found out how to create the config file using the internal program in dos box. However i cant get dosbox to use that file that it just created. I tried opening the terminal shell inside the application. and messing with that but i have no ideas. It says in it
CONFIG: Using default settings. Create a configfile to change them
when I already did create one. How do i get dos box to reconize that one exists?
Im using the Mac Dos box v0.63
my os is 10.4.3 (tiger)
1.25mb memory
