First post, by Guest
Hi,
what i imagine is, playing a game like dynablaster, which allows
multiplayermode at one pc, at 2 different pcs connected via tcp/ip.
Is it possible for example, that the second pc receives the image from pc1
and sends its key events back to pc1? 😀
Thanks a lot!
Mario
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
at the moment no.
and there are no concrete plans for adding it.
Water flows down the stream
Reply 2 of 3, by `Moe`
It is already possible with VNC. Some VNC servers can share a single window, and if you trust your partner to remote-control your app, then you can use that.
Reply 3 of 3, by neowolf
VNC's probably the sanest option at that. Most console emulators that support this sort of thing do so with rather crazy black magic and maintaining a horrifically delicate sync balance. With DOSBox there would be much more do go wrong as there's so much more that could cause either machine to be slower or faster than the other. Not to mention setup might be a real pain since both systems would need to be identical there too.
