Removing a mount
First post, by Ghost
Hi, I've just installed FEAR and when ever I try to run it an error message comes up asking me to deactivate virtual drives. I can only assume that it refers to the mount I made.
So, how do I remove a mount?
If ignorance is bliss then slap this grin off my face
Reply 1 of 3, by Kippesoep
Although I don't know FEAR, I would assume it doesn't mean your own mounts. Those are "removed" when you exit DOSBox anyway. It might, but it is probably referring to the mount of your CD-ROM drive, if you've not mounted it with the "-ioctl" switch. So, mount your CD-ROM drive using that parameter (I'm pretty sure the exact info is somewhere in the readme or the FAQ wiki).
My site: Ramblings on mostly tech stuff.
Reply 2 of 3, by eL_PuSHeR
F.E.A.R. is a very recent game. Either you are playing a pirated copy or you are using some virtual drive like Daemon Tools or Alcohol 120%. The message you are getting means the game protection (probably Securom 7.x or Starforce) has your virtual drive detected & blacklisted.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
