First post, by sehh
- Newbie
I'm running both Linux (Fedora Core 4) and WindozeXT Pro on the same computer.
I noticed that the windoze version of dosbox has a much better audio responce than the Linux version.
Both versions have working audio, with just a slight difference in responce timing. The Linux version seems to have audio thats about half a second out of sync while the windoze version is spot on.
Is this related to linux dosbox not able to raise priority if not run as root?
sehh
