First post, by Guest
Hi peeps,
after fighting with Dosbox, ScummVm and the image of Z for nearly an hour now, I'm kinda pissed off. I searched the forums (shortly) but didn't finy my problem.
Ok:
I got an image of the (surely known) game of "Z". I established a virtual drive with Alcohol 120%, installed the game, and try to ran it with Dosbox. No problem. At first it said, some files were missing, which should have been in the gamefolder itself but were on the cd. No problem so far, I moved the files, to the folder, no more errors on that. But the next thing that occured was the following: "Critical File missing: D:\cuts\G_logo.jv". D:\ is my virtual drive, and the file itself exists on this exact path, but dosbox still bitches around.
So any proposals?
Reply 1 of 2, by `Moe`
Did you mount drive D inside DOSBox? You have to tell DOSBox which drives it may access by mounting them. Read the README to learn how to do that.
