slow running
First post, by cel
hey ppls
all my games run slow in dosbox no matter wht i do
any suggestions??
Reply 1 of 12, by neowolf
Two tips.
#1 Read the readme.
#2 Details, details! What are you trying to run, what's your system like, what have you tried doing to speed things up?
"Omne ignotum pro magnifico"
Reply 2 of 12, by Spotted Cheetah
If you have some more recent machine ( > 2GHz) it should be safe to open the dosbox.conf file in your DOSBox directory, and set the emulated cycles to 15000 instead of 3000. It will speed things up. If you experience that the sound became choppy, set it lower (It means you tried to ask too much).
Left this dictatoric junk. No. IV.
Reply 3 of 12, by Guest
cheers dude
i've tried, duke3d,doom2,doom1,rise of the triads,heretic ,
and they all run slow ,, doom and duke run fine without sound tho
i got a athlon 2300+ with & 768mb of ram
Reply 4 of 12, by HunterZ
Try changing core=normal to core=dynamic on your dosbox.conf also. Note that this will probably only work for Windows and Linux versions of DOSBox.
Reply 5 of 12, by DosFreak
Anonymous wrote:
cheers dude […]
cheers dude
Those are all protected mode games (which in DosBox means slow), besides you shouldn't be running those games in DosBox anyway.
Duke3D: Use Jonof Duke3D Port
Doom1/2/heretic/hexen: Use Doomsday engine
Rise of the Triad: Use WinROTT.
Make your games work offline
Reply 6 of 12, by HunterZ
Good point DosFreak. I totally agree.
Reply 7 of 12, by Guest
ahh nice one,, hehe
havent tried any old games since i been usin xp ,, cheers 😁
Reply 8 of 12, by Guest
oo doomsday is wkd..haha
nice one 😁
anything for blood and quake?
sorry for bein pan 😜,, jus gettin into me oldskool games again 😜
Reply 10 of 12, by masu
where should I enter this?
beneath [autoexec]?
DOSBox 0.63
Windows XP SP2
Reply 11 of 12, by HunterZ
There should be a core= setting already in your dosbox.conf that you can change. If not then you should use the config command inside of DOSBox to generate a new dosbox.conf with a core= setting that you can change.
Reply 12 of 12, by eL_PuSHeR
Before you ask....
config -writeconf dosbox.conf
This will create a new dosbox.conf file inside your DOSBox folder. It's a PLAIN TEXT file containing DOSBox configuration. You can edit it the way you like using a TEXT Editor (like Notepad) (after closing DOSBox, that is).
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
