This is the exact line copied from my shortcut:
C:\walld\NY\send.bat C:\walld\MOC\opscon0 1
Here is the contents of my BATCH file
@ECHO OFF
REM CE FICHIER DE COMMANDE PERMET DE COMPILER, LINKER, ET ENVOYER
REM DES MESSAGES DEJA EDITES A UN PANNEAU VIPCO NEW YORK.
IF EXIST %1.MSG GOTO CPL
ECHO.
CLS
ECHO Voici la liste des messages disponibles:
DIR /W/ON *.MSG
ECHO.
ECHO Veuillez ecrire SEND, le nom du fichier sans extension et
ECHO le num‚ro du panneau
ECHO.
GOTO END
:CPL
COMPILE %1.MSG %1.DAT
LINKADD SEND.ADD %2 %1.DAT
LINKLOC SEND.LOC 663-8552 9600 SEND.ADD
CALLX LD SEND.LOC
DEL *.LOG
ECHO.
:END
Here is the dosbox.conf file
directserial=true
comport=1
realport=COM1
defaultbps=9600
parity=N
bytesize=8
stopbit=1
And I do not understand what you mean by the "serial1"
