First post, by xtz
When I try and run my executable via dosbox, I get an error message stating not enough memory to run. Now this system has enough memory, but i take it enough hasn't been allocated to dosbox itself? I browsed through the dosbox config file, and found memsize=x, and changed this to a larger number, but when i used 'mem' the amount of conventional memory hadn't changed. Erm any suggestions would be appreciated.
