MODEM HELP
First post, by IKE2
On my system, my modem is on com port 5 in WinXP Pro.
I have a couple of applications that require a dos based OS to run.
How do I set up DOSBox to access my modem for these applications??
Thanks
Reply 1 of 1, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Get a CVS build and type
serial1 directserial realport:com5
at the command prompt. Tell your DOS application to use COM1.
1+1=10
