fullscreen....
First post, by french_whore
Is there a way to switch between fullscreen/not while in DOSBox? Or if not, is there a way to close DOSBox in fullscreen mode without pressing ctrl-alt-del to terminate it?
Reply 2 of 8, by french_whore
besides ctrl+F9, none of that stuff works
And I didn't expect anything like that to be mentioned in the readme. It's not going to kill you to answer a question, that's what a forum is for.
Reply 3 of 8, by DosFreak
If you have an F-Lock key on your keyboard then turn it on/off. Then try the keys.
No, answering questions that can easily be read by the user in a readme will not kill me but it does waste my time. You see writing the message that I'm currently writing 50 times a day at least probably wastes what? mabye about 50 minutes? 50 minutes which I could be using to test DosBox. Therefore you are wasting MY time by not reading the readme and making me answer stupid questions. 😉
Make your games work offline
Reply 4 of 8, by eL_PuSHeR
Did they change the window/fullscreen mode toggle? I think it is ALT-ENTER
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 5 of 8, by Qbix
Rank DOSBox Author
DOSBox Author
and it's "exit" and not "quit"
Water flows down the stream
Reply 6 of 8, by french_whore
Thank you pusher and Qbix, for correcting DosFreak's answers to my stupid question. 😉
Reply 7 of 8, by eL_PuSHeR
You are welcome. 😎
Intel i7 5960X
8 GB DDR4 (2100)
