First post, by ChaosFish
- Member
I'm sorry if this has been asked before, I couldn't find an answer though.
I tried to use DOSBox 'fullfixed' with resolution 1280x1024. So it works, but there still remains unused space in the bottom and top of the screen.
How can I change the aspect ratio to make it fill the entire screen? "aspect=" under [render] doesn't do any difference.
Look at the attachment if you have no idea what I'm talking about 😜
Thanks in advance!
P.S. Please don't mind that "DOSBox Shell v0.65", I'm using the beta testers build but I guess that shouldn't make a difference 😀
