First post, by Martincg
NumLock stops the PageUp and Page Down keys from working. These are the seperate keys not the ones in the numeric keypad group. I have tried different keyboards.( UK extended)
I have looked at the relevant threads and the problem with numlock seems to have existed for some time.
If I write a dos program to show what the key code is when a key is pressed then in DOSBox
when usescancodes=true
--with NumLOck on, PageUp is 39 (ie '9')
----------------------- PageDn is 33 (ie'3')
-- with NumLock off, PageUp is 4900 (ie correct)
------------------------PageDn is 5100 (correct)
when usescancodes=false
--- PageUp and PageDn do not produce any key input whether or not
---NUmLock is on.
However, on my laptop PgUp and PgDn work ok with NUmLock on and off.
Is there a fix or work-around for this problem?
