First post, by zugvogel
I would like to use Dosbox to run older turbopascal-programs for scientific purposes. The problem is that the routines save their data to a folder on z:\
Unfortunately, dosbox uses z for system purposes.
I have read in another thread and the readme that Z:\ cannot be unmounted, but is there another option?
I would either need to rename the system drive (e.g. Y:\), or create a path on the harddisk which can be referred to by Z:\
Thank you for helping!
Reply 1 of 6, by eL_PuSHeR
Unless you edit DOSBox sources and recompile it yourself, you are out of luck.
I think it would be easier to modify Turbo Pascal code to store data in a drive other than Z.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 6, by zugvogel
What a pity, as I unfortunately only have the .exe of the turbopascal application.
Well, I'll try another DOS-emulator for windows then.
Any recommendations? It ought to be speed-adaptable like Dosbox, as the TP routine crashes on newer machines (in that respect, dosbox works quite well, but alas...)
Thank you anyway.
Reply 3 of 6, by wd
Rank DOSBox Author
DOSBox Author
Depending on how it was programmed, you might be able to change the
drive in the pascal executable as well using a hexeditor.
Also did you try some of those borland patchers? The problem you
describe is a well-known bug of the crt library and several fixes
are available that work on the .exe only (tppatch iirc)
Reply 5 of 6, by wd
Rank DOSBox Author
DOSBox Author
See e.g. http://www.brain.uni-freiburg.de/~klaus/pasca … 0/download.html
If it doesn't work out, you might want to upload the program and/or send
it to somebody, as long as it doesn't violate some copyrights.
