First post, by Inwards
I gather from the docs that one can use control-f4 to swap through the various disk images that have been mounted with imgmount. I have tried this with some ISO images have had no luck whatsoever. Is swapping ISO's supported, or am I doing something wrong?
Reply 1 of 19, by Qbix
Rank DOSBox Author
DOSBox Author
iso images are currently not supported in the swapping.
There is a patch for that and we are reworking it a bit for inclusion in the cvs.
Water flows down the stream
Reply 2 of 19, by SKARDAVNELNATE
I load my ISOs in Daemon Tools and mount the virtual drive. When I need to swap them I Alt-Enter, change the image, then Ctrl-F4. Other times I play around with combining the images from multible disks.
Reply 3 of 19, by whatever
on linux it is currently impossible (!) to swap CDs. if you use real CDs you cannot unmount them while dosbox is running, and with images swapping is still unsupported 🙁
i really hope this patch will be included in cvs very soon...
Reply 5 of 19, by whatever
i finally managed to swap discs by mounting both cds in different directories (in the linux filesystem), setting a symlink to one of them, mounting this symlink in dosbox and when the game needs the other disk i make the symlink point to the other cd's directory and press ctrl+f4.
well, it works this way, but i guess i don't have to mention that this sucks. swapping images in dosbox sounds a lot better to me, it's a pity that this feature was canceled...
could you explain the reasons why we won't see image swapping in future dosbox releases?
what about some "free file-handles"-hotkey to allow unmounting of cds in linux when needed?
Reply 7 of 19, by SysGOD
ok the official dosbox 0.70 readme says:
imagefile Location of the image files to mount in DOSBox. The location can be on a mounted drive inside DOSBox, or o […]
imagefile
be on a mounted drive inside DOSBox, or on your real disk. It is
possible to mount CD-ROM images (ISOs or CUE/BIN) as well, if you
need CD swapping capabilities specify all images in succession.
The CDs can be swapped with CTRL-F4 at any time.
but how should this look like? sry if i have missed something but iam not very skilled in such things. i think a bit more clarification or an example whould be helpfull for many users even if this feature is not well implemented yet...
Reply 9 of 19, by whatever
oops 🙄
well, i guess my dosbox build is broken then. if i try
imgmount d cd1.iso cd2.iso -t iso
dosbox will exit with a segfault. with a single iso file it's working fine, this is why i assumed it has not been added yet...
my binary was built from a cvs checkout of the day 0.70 was released. i'll recompile from 0.70 tar.gz and see if it works then.
edit: it _does_ work with the new binary, sorry about all the trouble
Reply 10 of 19, by SysGOD
i ask this because i have no idee how i should mount 2 different ISO images in one command line...
how should this look like? i tryed things like:
imgmount d c:\cd1.iso, cd2.iso -t iso
or
imgmount d c:\cd1.iso / cd2.iso -t iso
for example.
i think i get something wrong...
What's not well implemented there??
because of Qbixs posting:
Reply 12 of 19, by SysGOD
ive tested it now with my cue/bin images of mechwarrior2 and ghost bears legacy (all 4 files are on the root of my real C: drive for testing).
using it without any characters:
 imgmount d c:\mech2.cue gbl.cue -t iso
gives me only a "the image must be on a host or local drive" error...
Reply 13 of 19, by MiniMax
Rank Moderator
Moderator
Try
 imgmount d c:\mech2.cue c:\gbl.cue -t iso
_________________
Reply 18 of 19, by Qbix
Rank DOSBox Author
DOSBox Author
nada nothing!
DOSBox is dead. Nothing ever changes to it.
Usually the months before a release are the bussiest 😀
