First post, by Vaelor
- Newbie
Hi all,
I'm having some trouble getting my games to work with sound functional, when I try to run to run them from a Windows shortcut, using DOSbox with command line parameters.
They all work fine when I just run DOSbox itself, mount the drive manually, and then manually run the game's EXEs, and also fine through a front-end like D-Fend, but I specifically want to run them with command-line parameters so I can just create shortcuts to run straight off my desktop or Start menu.
As an example of the syntax I've tried, here's the command line I used to run Fury of the Furries:-
"D:\Program Files\DOSBox\dosbox.exe" "E:\Fury of the Furries\FURY.EXE" -exit -fullscreen -conf "D:\Program Files\DOSBox\DOSBOX.CONF"
I've also tried shortening the directories to the DOS compatible 8 character names, ie.:-
D:\PROGRA~1\DOSBOX\dosbox.exe E:\FURYOF~1\FURY.EXE -exit -fullscreen -conf D:\PROGRA~1\DOSBOX\DOSBOX.CONF
Another game I've tried was Leisure Suit Larry 7, with the same results:-
"D:\Program Files\DOSBox\dosbox.exe" "E:\Leisure Suit Larry 7\SIER.EXE" -exit -fullscreen -conf "D:\Program Files\DOSBox\DOSBOX.CONF"
And the DOS filename attempt:-
D:\PROGRA~1\DOSBOX\dosbox.exe E:\Leisure Suit Larry 7\SIER.EXE -exit -fullscreen -conf D:\PROGRA~1\DOSBOX\DOSBOX.CONF
As you can see, my goal is to run FURY.EXE (or SIER.EXE) via DOSBox, in fullscreen mode, to exit once the game is terminated, using the default configuration file.
Both games, as I mentioned, work just fine if I just run DOSBox, mount the drive, CD to the directory, and run the EXE. They also both work fine if I mount them in D-Fend and run them that way. However, clearly something is wrong with either my command line syntax, or my config file, because when I try to run them via the above commands, the games load and run fine, but completely soundless!
Can anybody make sense of this puzzling issue and tell me what I'm doing wrong, or help me troubleshoot what I'm missing or overlooking to successfully run my games via command line with working sound?
Thanks in advance!
Vaelor's Keep
