First post, by ADDiCT
I remember from the old DOS days that some games needed a VESA driver like SDD installed/configured in order to run in different resolutions.
Is this also necessary inside DOSBox? I mean, do i have to run a utility like SDD inside DOSBox, or would that give me any kind of advantage (performance, resolutions)?
I've installed Terra Nova - Strike Force Centauri yesterday, and it seems to generate a VESA driver of it's own. With this driver active, however, i can't see anything on the screen, even though the games seems to run OK (i can hear sound and am able to blindly navigate menus etc.).
My bet is that the emulated graphics adapter already has basic VESA support, and i do not need any additional drivers/utilities.
Reply 1 of 4, by eL_PuSHeR
DOSBox already has built-in VESA 2.0 support.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
actually we emulate 2.00
univbe and such work in dosbox (use older version 5.3 or so)
they add a few exotic screen modi, although they aren't always needed (depends if we programmed the wanted mode of the game allready or not)
Water flows down the stream
