First post, by butterfly
- Member
Using the standard config file (of ver. 0.70) with DOSBox 0.70, USB joystick Logic3 PC USB GAME-PAD is no longer recognized within DOSBox using either:
joysticktype=auto
or as in the old config:
joysticktype=2axis
I tried to play with the other joystick configuration options in the conf file but it didn't seem to work.
The joypad drivers are installed and it works in Windows. The same joypad used to work with DOSBox 0.65
Any tips besides using the keyboard mapper?
