First post, by Gene Wirchenko
Back in October, I wrote about a problem I had with DOSBox 0.65:
I am using WordStar 2000 under DOSBox 0.65 under Windows XP. If I started WordStar with a filename specified on the command line, and the file already exists, it will not work. I get a message "Can't open another window for editing or printing-- the current disk or directory is full. Press Escape." If I then try to open the file from within WordStar, I get the normal editing display with no contents showing and WordStar locked up. I have to restart DOSBox. Etc.
I have just installed DOSBox 0.70, and the problem is gone. 0.70 appears to be faster, too!
Sincerely,
Gene Wirchenko
