How do i make a video with dosbox
First post, by abyss
How do i make a video with dosbox.
Reply 9 of 17, by Kippesoep
Check out section 5 of the README, specifically the keys for "Start/Stop creating a movie of the screen. (avi video capturing)". There's not a whole lot to understand...
My site: Ramblings on mostly tech stuff.
Reply 11 of 17, by Kippesoep
Wow. I hadn't imagined anybody would not know those things. Have you seriously never pressed a key combination like Alt-F4 or Ctrl-Alt-Del? "Ctrl" and "Alt" are like the "Shift" keys on your keyboard. You hold them down, then press F5 (release them in any order you like).
It stops recording when you press Ctr-Alt-F5 again or when you quit DOSBox (not the game).
AVI is the main format Windows uses for video. Just double-click on an AVI file (it will appear in DOSBox' "capture" directory) to play it, probably through Windows Media Player. For more information, check out the "README.txt" file in DOSBox' "zmbv" directory.
Reply 13 of 17, by Kippesoep
Then you haven't followed the instructions in the README.txt in the zmbv directory:
To play the recorded movie, you need a movie player which can handle the
ZMBV codec. MS Windows users can find this codec in the start menu entry of
DOSBox.
