First post, by rustybutt
- Newbie
I'm a newbie to dosbox. I've run it on both Ubuntu 6.06 and Win XP. Pretty cool. The application I want to run is the old Ashton-Tate product called Framework, which was a character-based windowing based integrated office package - spreadsheet, word processing, etc. It was nothing short of amazing in 1984!
It seems to run OK under dosbox, but now I'd like to run it with a screen that is 132 characters wide, not the standard 80. More characters means more "real estate" in Framework. I used to do that with SVGA mode on a 14" SVGA monitor way back when.
Is there some way to do that with dosbox? Is this a matter of fonts? Is there a commercial add-on that I could buy which would do the trick?
Do you Ubunutu?
