Reply 20 of 20, by mario_lorenz
Hi Acefox,
i´ve the same problem like you. In the Fullscreen mode is sets the screen on the y axis too far above. That concerns all emulated resolutions (Text80x25, 80x50, VGA 320 x of 200 etc..) in the Fullscreen mode.
It is all the same with all resolutions in that I´ve start DOSBox 0.70 (1024x768x32M, 1024x768x16M, 1280x1024x16M, 1280x1024x32M).
The normal Fullscreenmode on the DOS-Prompt works fine.
Regards,
