First post, by dbarton
To set where DOSBOX MIDi s going, I select output in XP's control panel.
I'd like it to go to *two* places, but I can only select one in XP.
I want Dosbox MIDI to go to a USB midiport *AND* to a second place - the input of an XP music program..
Any way?
Reply 1 of 6, by dh4rm4
Both MIDI-Yoke (which is more compatible with Windows 2000 than XP) and MIDI-OX (the latest version MIDI-OX32 was built with XP in mind) might do what you need - as long as DOSBox's MIDI output is standard. Essentially you install either app as a midi driver (Under Sound and Audio devices in XP) and then you can elect to route inputs and outputs virtually. Many computer musicians use these apps to 'play' virtual instruments.
http://www.midiox.com/myoke.htm - MIDI Yoke
http://www.midiox.com - MIDI-OX
Reply 2 of 6, by dbarton
I use these programs, but I dont see how they can do just what I'm asking.
If i send dosbox midi to hardware MIDI I/F, its not being sent to Yoke.
If I send to Yoke instead, then hardware doesnt see it.
Another PROGRAM can see it, but the MIDI I/F can't..
Reply 4 of 6, by dvwjr
You might want to check out the MidiTrix product by Mr. Hermann Seib, who has written quite a few MIDI utilities. This might be what you are looking for from your problem description. Works with Virtual MIDI cables...
The link is MidiTrix at his website...
Hope this helps,
dvwjr
