First post, by Pan
Hi all
Is it possible to change the keyboard mapper from the command-line? I've tried a few times, but never had any luck with it. The command is accepted, but seems to make no difference to the mapping.
[Edit] Sorry, this should probably of gone in the general forum, but it seems I don't have the permission to move it.
Reply 5 of 7, by IIGS_User
Some things seems to be accepted but not be changed,
I discovered while developing a DOSBox front-end...
Klimawandel.
Reply 6 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
Correct. I didn't implement all the options in the runtime modification code.
but using a configuration file or using env variables should work
Water flows down the stream
Reply 7 of 7, by Pan
If I get time in the summer, I might give myself a refresher into C/C++ and look at that code 😀 I'd like to make Dosbox more configurable from the command-line. Could be an interesting project 😀
