First post, by Pseudo
HI,
I'm trying to play Goblins 3 on my computer. I have the game on floppys (5 disks)
I tried some things but it did'nt work...
Can someone help me with the commands?
Do I need to install the game with DosBox?
Or copy the files of the floppys to a folder on my hardrive before I run DosBox?
Thanks in advance.
Reply 1 of 4, by MiniMax
Rank Moderator
Moderator
Yes, you should install it from inside DOSBox.
You should be able to use the 60 seconds guide in my signature.
Just remember to not mount your CD-drive as drive D, but your diskette drive as drive A, e.g.
Z:\> mount A A: -t floppy
And every time you change diskettes, use CTRL-F4 to let DOSBox know that a new diskette has been inserted.
_________________
Reply 2 of 4, by Pseudo
thank you.
I'm able to launch to install but it doesn't work: The install program says it can't find the c:/ drive (to install c:/coktel/gob3).
It then gives me a list of drives to choose from (c: to z:) but nothing works...
Any suggestions?
Thanks again.
