First post, by eftekhary_h
Hello ,My friends
I Run DOSBox in Win 2003 ,I have Network Novell in Dos but when mount drives'Novell in DOSBox and run my program sorry dont excute right becuse my program dont found the path please hint me
with regard
Reply 2 of 9, by Zup
Maybe you'd get better results executing your program through VMWare (some versions are free). The rule about emulators is:
- For playing games: use DOSBox. It's unbeatable emulating sound cards and video cards.
- For DOS applications: use VMWare. Included Parallel port support, and it emulates a PC, not DOS. You may install DOS and Netware drivers and it will work flawlessly.
(P.S.: If you don't need printer or net support under DOS and your app works with DOSBox, forget about VMWare)
I'm selling some stuff!
Reply 3 of 9, by eftekhary_h
I want run application'Dos version in another computer with Remote by my computer I used many application for Remote connected to that computer for example ( Dame Ware,Remote Administrator) in windows XP,2003 but application'font Cumbered then I showed DOSBox software
and used that. my application is not game and Run in Novell network
can help me VMWare for solve my problem ?
I need solve this problem please help me .
thank you
Best Regard
Reply 4 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
you don't need novell for dos.
you have to mount your drives (novell ones) in dosbox like any other drive.
you have to use novell for windows to make the drive avaialable to the host you run dosbox on.
Water flows down the stream
Reply 5 of 9, by eftekhary_h
Dear QBix
I Created Novell's Dirves with Map Drive utility in win 2003 and windows found all drivers then I mount all drivers in DOSBox and I successed
but when Run my SoftWare , sorry My SoftWare dont found drivers and give error about path
I view all of drivers in DOSBox after defined those by mount key but My Application don't view those
Reply 6 of 9, by MiniMax
Rank Moderator
Moderator
eftekhary_h, please tell us the commands you use to mount the networked drives in DOSBox.
_________________
Reply 8 of 9, by MiniMax
Rank Moderator
Moderator
Tell us the exact commands you use in DOSBox please.
_________________
